What Eagletree system do I need??
I borrowed one and loved it, but didn't remember to look what it was. What do I need...I want to be able to move it to my truggy's and buggy for testing.
http://www.hobbycity.com/hobbycity/s...&ParentCat=172 |
Do you need the base unit, or an attachment? The base model is the elogger. Optional parts depends on what you are trying to measure.
Well, the base unit will monitor amperage and voltage. And to get temp, all you need is the temp probe (just a thermistor attached to a servo plug really).
These are what you need: http://www3.towerhobbies.com/cgi-bin...&I=LXTNL1&P=ML (make sure you get the 150A version) http://www3.towerhobbies.com/cgi-bin...&I=LXPBP3&P=ML |
This one it?? http://www.hobbycity.com/hobbycity/s..._Data_Recorder |
You could probably find a better price if you look around. I just knew Tower had them so I could show you what you needed with pics.
If you are inclined you can make your own temp probe using a Rx harness cable and a 10K ohm NTC thermister. I ended up making 2 extra ones for about $2 buying the parts and the temps are within 1 degree of each other.
Jeff |
I did the same, except I happened to have a thermistor laying around. I know, I know; what kind of nerd has a thermistor just laying around right? :oops:
:neutral::whistle: I won't say a word. You should have seen my garage this weekend. I must have thrown away 10K resistors and several hundred caps, transformers, IC's and all kinds of crap, but I still have way too many of just about everything.:oops:
Jeff |
Look who's talking! At least I know I'm not coordinated enough to be on a skateboard! :tongue: Quote:
I still kept a lot of components don't get me wrong, but some of it was just too old and near the end I started chunking stuff I know I will regret. But there comes a point where you have so much crap that you end up buying the part because you can't find it but you know you have it, then you find it after you finished building whatever it is.:cry: Jeff |
I know that's right. We had a sitsuation a few years ago and were looking for some obsolete componets and ran across a few companies that we got them from and they were about twice what we had paid before. I hate how a lot of these manufacturers make a part and we incorporate it into something and within a year it's obsolete or you can only get it in a SMT. I remember one component that we bought little SMT to through hole adapters to hold us through until the revision could be made on the board. It was like a digital pot I think the DS1267 or something llike that. That was a pain most of our stuff now is SMT but even some of those componets do the same thing. We have 1 card that is on it's A rev. and another that's going on it's F rev. simply because of component obsolenance. I am glad I don't really have to deal with it except for repairs sometimes, and UL. Don't even get me started on UL. Jeff |
| All times are GMT -4. The time now is 05:05 AM. |
