Weird: My throttle stays on for a second after I release the trigger?
Something weird happened today at the track. My throttle seems to be staying pinned for a second or two after I release the trigger on my TX.
My set-up: - Futaba 3pm Fsst (nothing has been tweaked on it for the majority of the summer ). - Throttle trim at 0 - Tekin 2000kv combo (has been running like a champ since late July. - 4S -MBX6T I did adjust the timing in Hotwire this morning (turned it down to 0 because of the Hyperon g3 batts power), but that's it. Upon further inspection, I noticed the sensor wire is bent at a weird angle now, and is showing signs of wear. Could this be it? I am not sure. Made it real hard to jump. I am used to it being perfectly level, however now that it's sticking, it jumps nose high slightly, because of the extra second of throttle. Have you ever heard of this happening? |
Just removed the sensor wire, and still, the same thing. In my basement I would drive it slow, then brake, then it would lurch forward another 6 inches or so. Same with accelerating, after I let off, it still goes.
Not sure here. |
Check push control or increase your throttle dead band in the ESC.
Actually it sounds a l ot l ike what push control does... |
Do you have a different ESC to try, like a MM or MMM?
Yes, it was the Push Control. Ooops. I "must have" moved that slider as I was adjusting my timing (right next to each other in Hotwire software).
Thank god it was an easy fix. |
| All times are GMT -4. The time now is 02:29 AM. |
