-   -   Something Wrong (https://www.rc-monster.com/forum/showthread.php?t=2418)
Mike.L 02.22.2006 10:53 PM
Something Wrong
when you have one problem a nother one comes up.:035: ..i have noticed that when i switch the power switch back onn and my remote onn neither the throtle works nore the steering i have double cheked my bateries and theres nothing wrong. replaced them with new batteries..no wires are cut..and i have my entenna still soddered to my reciver. does this mean my reciver is fried?:013: :035:
squeeforever 02.22.2006 11:11 PM
make sure that your switch isnt installed backwards where on is off and off is on. ive done that once or twice:013: batteries (if using dry cells) arent in backwards...
coolhandcountry 02.22.2006 11:21 PM
Do you have another power source to try them on? I would try to bypass the switch to if it don't work. Make sure your crystals have come loose.
Sneeck 02.23.2006 01:38 AM
Same thing with receiver cristal's. Make sure your useing the right one's(tx in transmitter)
Sylvester 02.23.2006 09:26 AM
^^^Check all of the above^^^
Mike.L 02.23.2006 05:59 PM
ok im going to try something if so i could always get a new reciever
standard_63 02.23.2006 06:48 PM
Be sure to switch the transmitter (remote) on before the receiver (truck).
crazyjr 02.23.2006 08:21 PM
Try using thr battery without the switch, I've had that problem before and that was the problem
Sylvester 02.23.2006 08:25 PM
Youve wasted a bit of money on that thing, IMO you should trash that POS. lol
