Removing mechanical brakes on Aftershock
I am thinking about removing the mechanical brakes on my Aftershock, and move the battery tray up front and the esc back, to get a better weight distribution.
But do I just remove the servo for the brakes, or shall I do some more? |
You can do that, or you can also take the diff assembly apart and pull out the disc's too.
As Jeff stated you can do either...on all of my conversions I have removed all of the brake parts...discs, etc. to make a cleaner conversion.
OK, thanks for the replies.
| All times are GMT -4. The time now is 07:58 PM. |
