808e Neu 1512 clearance question
Hi. I've an 808 I'm converting to electric. I've installed the RCM motor mount and have found that when I attempt to install my Neu 1512 (finned) motor it hits the nearby mud guard mounting nut.
I see that people were removing the nut and dremeling off a bit of the plastic when using the XB8 mount. Is this still what needs to be done? Thanks. |
take the nut/bolt out and cut off the plastic thats hiting it with something, exacto, dremal, etc
I (and many others) have used Mike's 808 mount with much success.
The nut does need to be removed, though you don't neccesarily need to remove the plastic surround as well. |
Thanks. Just wanted confirmation before I started cutting. I removed the nut and trimmed the surround a bit and the motor fits fine.
| All times are GMT -4. The time now is 08:09 PM. |
