Strengthening 3905 motorplate for brushless needed?
Is strengthening the motorplate on a 3905 trans needed for a BL motor? It seems kind of thin to support the weight. Does anyone have any ideas, or am I just overly concerned? The MAXX is going to be used as a basher. Thanks!
-JB |
You won't have any problems. Something else with break before it gives you problems. |
I'll second what sikes said, if you're using a Feigao the motor will come apart from impact before you'll bend the plate... no worries there.
In my Revos. I was chipping Spur gear teeth during hard landings so I made a brace and it has cured the problem.
If nessasary you could do something similiar. http://i88.photobucket.com/albums/k1...z/P8180008.jpg |
Nice solution Jeff.. no doubt you bash harder than I...
Bow befor me :whip:
Uh well that ain't happenin.
Nice try tho :lol: Head to head with the Mute- ya ready? |
Going to the track Friday, looking forward to runnin' laps regardless how bad I suck. It's all Fun ! |
I'll have you know the Mute took the 2006 'safest midsize RC' award. Not safe so much for the occupants, but safe itself :lol:
You'd still take a wheel off it tho, damn brute you are! |
I've also heard of using two motor plates(double) if the motor shaft will allow for the pinion the engage properly w/ the spur.
contra to popular belief.
i dont believe the standard 3905 tranny needs beefing up. you see... the E-revo tranny mount is 3mm thick ally, this has a spacer that spaces the motor a further 20mm away from the motor plate. the motor weights a LOT!! mechanican advantage must be massive and hence the playe bends a little on hard landing, the extra torque put on the gears during a landing combined with the flexing of the motor plate bends the spur/pinion out of mesh and therefore strips. ON THE OTHER HAND! my setup, same as the old BL-emaxx setups people used to do has the motor mounted high on top of the tranny. this is rubbish for COG i could imagine BUT there is a flip side to this. the motor (castle neu 2200) only has about 2mm to bend down before it hits the tranny. upon hard landing, the motor only moves down a very little way, the mesh stays in close contact and the tranny plate is able to flex back into it's original position. make sence? due to this theory, i have over 40 hours of use on my first and only spur gear i have ever used in my revo convert!!, ye-ol 65t still looks in great shape and i have no intent on changing it any time soon :mdr: |
| All times are GMT -4. The time now is 07:38 AM. |
