Mamba Moster Max BEC and maxi servo
I would use this maxi servo on Mamba Monster Max with its internal BEC.
http://www3.towerhobbies.com/cgi-bin...?&I=LXN610&P=7 Theese are the specs of the servo: 8mA idle and 800mA at zero-load operation Speed: 0.20 sec. at 60° w/ 8.4V battery. Output Torque: 16.0 kg-cm (224 oz-in) at 4.8V. Can I use it without problems or do I need an external BEC? How many Mah can handle the mamba monster max BEC? |
yeah...very very slow!!!
you'll need a very long arm in it to speed up the steering response. |
Q. What vehicle was this servo going to be used in?
I would use it in this homemade vehicle:
http://www.rc-monster.com/forum/showthread.php?t=23285 I know that this servo is very slow, but my ask was if mamba monster max can handle this servo without external BEC. Now I'm using a Tower Pro MG995, I think this hitec maxi servo could work better. |
I believe the BEC in the MMM is rated for either 3 or 5amps @ ~6v, so it should be fine. That said, I would go with a better servo regardless- hobbycity sell a ton of really nice items with similar torque ratings & metal gears, worth having a look around before settling on that hitec monster.
Ok thanks for mamba monster bec specs, I will see on hobbycity for a faster maxi servo with metal gears instead of this Hitec. |
| All times are GMT -4. The time now is 08:54 AM. |
