-   -   V3.19 Software now available (https://www.rc-monster.com/forum/showthread.php?t=24262)
Pdelcast 10.28.2009 03:55 PM
Gents,
We found a bug in 3.18 that was causing issues with startup in sensorless mode on the Mamba Pro, and on the Mamba Monster.
A new version, V3.19 (now available at www.castlecreations.com) fixes this issue.
Thanx!
Patrick
snellemin 10.28.2009 03:59 PM
coolbeans.
nitrostarter 10.28.2009 04:05 PM
Does this fix the smart sense start up also?
shaunjohnson 10.28.2009 04:30 PM
Originally Posted by snellemin (Post 329913)
coolbeans.
curl curl beans, beans curl beans
COOLBEANS!!!!
Arct1k 10.28.2009 05:45 PM
Drag brake????
FastXR 10.28.2009 06:09 PM
Originally Posted by Arct1k (Post 329928)
Drag brake????
Im starting to get the impression you are looking for some drag brake changes. :mdr:
magman 10.28.2009 09:10 PM
Thanks Patrick for the heads up. Little things like this is why we love your company!
sikeston34m 10.28.2009 10:32 PM
+1 on this! :yipi:
Pdelcast 10.28.2009 10:45 PM
We have one more firmware update for the MM Pro due in the next week or so -- so I'll have Richard sneak the drag brake update in that release... :yipi:
snellemin 10.28.2009 11:18 PM
Will this dragbrake also be for the mamba max?
sikeston34m 10.28.2009 11:22 PM
Ummm.........Since it's in the "Car" software, it could be for the MM Pro, the MM AND the Mamba Monster.
Confirm? :neutral:
Freezebyte 10.28.2009 11:41 PM
When will we might get a new firmware update with fan temp control?
snellemin 10.28.2009 11:46 PM
Well the 3.19 didn't update my two mamba max's, that's why I asked.
I kinda like dragbrakes, as I lose brakes at time with high kv motors and the dragbrakes always work. Work around is to lower the brake epa a bit.
etc1006 10.29.2009 12:13 AM
And I guess it won't do Vista w/ the MM yet?:no:
MetalMan 10.29.2009 12:19 AM
Vista 64-bit? If you have 32 bit it should work perfectly.
