-   -   TC4 chassis help needed (https://www.rc-monster.com/forum/showthread.php?t=24264)
phildogg 10.28.2009 05:15 PM
I've been having probs with the car pulling hard to the right,(running a mm/5700 2-3s lipo). I started looking into it and found that if I push down on the right rear shock the front left tire raises up. Now If I push on the left front the right rear raises. whats the prob here? The othe 2 corners are fine.. thanks in advance.
phil
simplechamp 10.28.2009 05:31 PM
When is it pulling? All the time? During acceleration? During braking?
If it's during acceleration it could be torque steer
phildogg 10.28.2009 05:38 PM
It does it during acceleration but my question is about why the chassis rocks on the two corners,I think thats the problem now.
phil
phildogg 10.29.2009 12:50 PM
anyone else? surely someone races these.
phil
What's_nitro? 10.29.2009 01:06 PM
Are the shock springs set to precisely the same preload? Is there any binding in the arms or sway bars (if you have them)?
PBO 10.29.2009 07:24 PM
Have you tried the AE forums?
http://www.aeforums.co.uk/forum/index.php?showforum=16
It may be a quicker way of getting the answer although I suspect Problem Child has already identified it - he has a lot of experience with these set ups
