-   -   90 degree bullet connector? (https://www.rc-monster.com/forum/showthread.php?t=24278)
zviper 10.29.2009 02:45 PM
can i drill out the side of a 6.5mm bullet connector will that work or would it be a waste?
when i shorten my motor wires on the cc 2200kv do the wires have to be the same length?
GO-RIDE.com 10.29.2009 02:52 PM
That's what I did to mine. Be careful. Once the hole is big enough for that large wire there's not much metal left.
Jabe 10.29.2009 02:58 PM
Just drill/cut ONE side out, that way you have enought contact surface.
BrianG 10.29.2009 03:00 PM
That's what I do and it works great. I've never done a ful 90*, but sometimes I make a 45* angle and it's a good compromise between an angled connector while still allowing me to get a single piece of heatshrink over it.
zviper 10.29.2009 03:05 PM
so instead of making it 90. just grind out the bullet so i can angle it around 45?
and what about cutting my cc2200kv motor wires do they all have to be the same length?
bdebde 10.29.2009 03:16 PM
I bend the wire 90 before I tin it. And yes, motor wires should all be the same length.
V0RT3X 10.29.2009 03:17 PM
The bullets on the MMM are 6.5mm right? (motor has 5.5mm stock?)
BrianG 10.29.2009 03:22 PM
Originally Posted by zviper (Post 330109)
...and what about cutting my cc2200kv motor wires do they all have to be the same length?
Ideally, they should be, but I personally do not think it matters if there are slightly different so that they reach where they need without stress or too much slack. Mostly aesthetic.
PBO 10.29.2009 05:10 PM
I tried slightly different wire lengths & made no noticable difference compared to common length wires
If you're concerned about heatshrink over 90 degree bullets? try self amalgamating tape, it works very well
http://www.heatshrinksystems.com/epr...ating-tape.htm
zviper 10.29.2009 05:15 PM
1 Attachment(s)
ok so i went ahead and just bent then and tinned them worked wonders. i dont see the problem with using shrink tube on a 90. thanks for the help guys
PBO 10.29.2009 05:28 PM
Haha...that's cause it's not 90!
zviper 10.29.2009 05:31 PM
close enough lol
PBO 10.29.2009 05:53 PM
Looks nice though, think I'll do that rather than the drill out, 90 method next time
zviper 10.29.2009 06:44 PM
i used adhesive shrink tube if that helps
