-   -   36120 maxx rpm.....how do you know??? (https://www.rc-monster.com/forum/showthread.php?t=2430)
rcjmaxx 02.24.2006 12:13 PM
I just received my 36120 in the mail and noticed in the description "42000 maxx rpm",well how do you when you've reached this limit? I assume the number or cells and gearing will determine how fast you reach this point but is there a way of knowing before you do damage to the ESC? Thanks
RC-Monster Mike 02.24.2006 12:18 PM
The simple way is to calculate the voltage and the motor Kv and add a saftety margin(motor will spin faster when not loaded). I use 38000 rpm as a "target" for motor/voltage selction. Hope this helps. :)
coolhandcountry 02.24.2006 12:58 PM
If the figure you get is under the 42000 you should be good. Depends on the kv rating and cells.
What kind of setup you going to run or is it top secert?
Serum 02.24.2006 01:52 PM
You don't want a big motor to turn too fast either. (assuming, that you are going to use one big badass motor..)
nitrostarter 02.24.2006 02:50 PM
36 cells is an aweful lot of voltage. Must be a motor the size of a coke can.......
Serum 02.24.2006 03:21 PM
2250 or 2240 can do the job 'already'
rcjmaxx 02.24.2006 05:02 PM
Truck is a TXT-1 thats 13.5 lbs with a Feigao 12XL and 8 lipo cells,currently using 54t spur and 14t pinion.No bashing,topspeed running only.
rcjmaxx 02.24.2006 05:08 PM
Understood,but....should I not run full throttle? Is there a point where I should let up? I have a GPS to record MPH,but is there a way to know when to back off?
coolhandcountry 02.24.2006 05:14 PM
a motor not under load should hit about 41100 rpm. I think you be safe while running. On 8s lipo any way.
captain harlock 02.24.2006 05:21 PM
Does the 3695 have a 42000 rpm limit like the 36120? will the first handle a 1950/10 at 24volts using 34/51 pinion and spur in a heavy truck?
Serum 02.24.2006 06:24 PM
3695 hasn't got this limit.
Only goes for the 36120 and 150A
captain harlock 02.25.2006 06:50 AM
What about the other question,pal?
Serum 02.25.2006 08:05 AM
Should do, i would consider taking a smaller pinion though.. 34 is a bit on the large side It will take WAY more amps than the 95A controller is capable of, so, run a higher voltage, with a lower KV motor or take another controller.
Does it use UE diffs or normal diffs?
Here check this calculator. i guess you know what to do with it. You need to put *1.75 behind the value of the 'gearing ratio' if it runs 2nd gear.
Gustav 02.25.2006 08:08 AM
Setting the mesh is tricky if your using a motor plate,anything over about a 27T mod1 makes it difficult to reach the screws,so you'll have to snug them up,then take the pinion off to tighten them.I realised this recently,i'm going to make a sleeve instead to mount the motor.
captain harlock 02.25.2006 10:34 AM
Mike told me that he can hook me up with a 36 teeth pinion using the setup I mentioned above with the exception of the 3695 ( I'll be using the 9918 for the meantime).
