hungry truggy
1 Attachment(s)
any ideas on how to stop my rcm pinions from getting eaten? motor and mount are solid(not loose) they pinion is meshed up nicely against the spur.i ran my 14t for 4 battery cycles and no problems.then today it got eaten along with a 15t pinion of mine on loan to another brushless truggy(this one completly stripped all the teeth)
I would start with checking the motor mount and making sure it isn't bent. Even a slight bend in the mount will cause short life of pinions. I've managed to bend 2 motor mounts from Mike. My terrible driving skills didn't help, but they were not hard to get flat again.
If you're eating up pinions then something isn't right between the gears. I usually run 15 or 16T on my truggy and a 17T on my buggy, both have metal spur gears. Only time I've damage a pinion was with a bent motor mount or my gear mesh was off. |
+1 on the above advice....also, try to turn the spur all the way so that you can see the pinion teeth work its way over all of the spur gears teeth...i had one part of my spur gear in my old 8ight that wasn't as worn as the other sides so my gear mesh was fine until it hit the un-worn spot.....and from the looks of your pinion, it really might be a slight bend in the mount or chassis that flexes a bit too much when you land from a jump or hit the throttle...just my 2cents.. :)
also are you using a metal spur? cause when i used a metal spur the same thing happened to me.
Yep... Just lost my 14 tooth last week... the motor had a very slight movement with the mount and I was using a metal spur... The guys above are correct,
there must be some misalignment for that kind of damage to happen to the pinion. |
Is Impact from a jump, allowing the weight of the motor to flex the mount?
This would cause some misalignment also. |
Before I started I thought my method would be too crude to work. But the mount wasn't doing me any good bent and it would beat buying another one if it worked. |
I would give Robinson Racing a try, I have so far never been let down by there hardened steel. http://img528.imageshack.us/img528/9...bell001tj3.jpg this is my experience with pinions that were softer then the spurs. |
It almost looks like a rock got between the gears. It broke the first tooth off then bent the mount. Mount is probably bent because the gnarled teeth on the pinion are at an angle. Just a wild guess..
i dont know what your truck is using for a spur but i run the kyosho 44 or 46 tooth nylon spurs http://www.rc-monster.com/gears.php?pg=3 and if for some reason something happens the spur would give before the pinion would. so in the long run it would be a better choice based on price. my truck came with a 53 tooth spur and i run the 46 tooth and gear it to the speed i want to get.
When filed I found out the bell was a softer steel then the spur. |
| All times are GMT -4. The time now is 10:16 PM. |
