-   -   Lipo RX pack, which one? (https://www.rc-monster.com/forum/showthread.php?t=2440)
Superemaxx89 02.25.2006 05:49 PM
I don't know which one I should get. I don't know how many amps it needs to be rated for either.
I will be powering 2 fans, 2 servos, and the esc.
Will the UBEC do the job?
Serum 02.25.2006 05:58 PM
UBEC should be fine, no worries.
maxxdude1234 02.25.2006 06:01 PM
A uBEC should do the job. On www.koolflightsystems.com they say its rated for 8-10 servos, 3A continuous and 5A for 5minutes. Those little fans won't draw more than about 0.2A each, so you should be fine with the uBEC
coolhandcountry 02.25.2006 06:23 PM
and the best part is you don't have to worry about charging it.
MetalMan 02.25.2006 08:04 PM
I'd be worried about using Lipo for an RX pack. If the pack drops below 6v (2s Lipo), then you could be screwed, as in the vehicle could have melted plastic.
