-   -   Problems with calibrating MMP (https://www.rc-monster.com/forum/showthread.php?t=24490)
Ferret 11.13.2009 02:56 PM
Got my MMP (running the original V1.22 software that it came with).
When I tried to calibrate it (turning the switch on while holding full throttle etc...) it registered forward fine but it didn't register brake/reverse ( and of course I didn't get to the neutral calibration part).
I'm running 2 MMs and one MMM in other cars with the same radio gear (Spektrum DX3R) and never had problems calibrating.
I tried to reverse the throttle channel and different throttle/brake end points but it didn't help.
Any ideas how to calibrate?
BTW - I tried running the car without calibrating the MMP and everything seems to be acting normally, the MMP isn't dead or anything, just won't calibrate.
whitrzac 11.13.2009 02:59 PM
make sure that the brake EPA is at 125
Ferret 11.13.2009 03:06 PM
I tried EPAs of 100%, 120% and 150% and none worked.
whitrzac 11.13.2009 03:26 PM
I know that spek. dx2/3s have a "secondary" EPA on the grip that can affect the calibration...
Ferret 11.13.2009 03:41 PM
I just verified the the EPA on the grip is set to max.
I also tried setting the EPA to 125%.
Still registering forward but not brake/reverse.
BrianG 11.13.2009 04:16 PM
I had a similar problem with one of my MMPros. I tried a few things and can't remember which worked, but I fiddled with the throttle trim and also reflashed the firmware.
Ferret 11.13.2009 04:29 PM
Brian,
did you reflash to the same version or to a newer (beta) version?
Avner.
BrianG 11.13.2009 04:36 PM
Actually, I flashed to an older version, and then again to the current version.
Ferret 11.13.2009 06:34 PM
Ok, problem resolved.
I tested several firmware versions and the problem occurs only in versions 1.22 and 1.23.
Versions 1.21 and 1.24 calibrate without any problems.
Avner.
muck 11.14.2009 09:25 AM
good to know. I hope to see my MMP early this week.
fastbaja5b 11.15.2009 08:31 PM
I had the same issue, updating to the latest firmware seemed to fix it
