-   -   lst centre diff mount (https://www.rc-monster.com/forum/showthread.php?t=24519)
lind5 11.15.2009 03:29 PM
hi guys well i have a brushless lst2 that i converted a while ago
it has the g/max single speed gear box conversion
all metal gears
mamba monster 2200 kv combo
i run on 4s and 6s
im thinking of putting a center diff on it to karm down the power wheelys
so what im looking for is a motor mount where the motor will sit above/behind the center diff
i have looked at mikes mounts and they all sit horozontally to the diff
i need one that is vertical
can any one help cheers guys
Bondonutz 11.15.2009 07:27 PM
I'd be curious to see one as well ?
suicideneil 11.15.2009 08:15 PM
Mike can make a custom vertical mount, but it'll take a while to get finished I imagine. Otherwise, you could mount a normal center diff conversion vertically, then make some additional mounts to hold it in place- will need to bolt onto either 'side' of the diff and bolt down on to the lower chassis plate.
bdebde 11.16.2009 01:34 AM
Or you could DIY
suicideneil 11.16.2009 08:01 AM
Amen to that^. :yes:
