-   -   Vid of MMPRO creeping with 21.5 LRP (https://www.rc-monster.com/forum/showthread.php?t=24560)
snellemin 11.18.2009 12:39 AM
Here's a vid of the MMpro creeping in my FLM Rustler with a 21.5 LRP stock motor w/14mm sintered rotor upgrade. Batteries were 6s1p A123.
http://www.youtube.com/watch?v=WTF1u1VNXgI
</EMBED>
bigboi146 11.18.2009 12:53 AM
It seems very smooth I've been looking forward to getting one!
snellemin 11.18.2009 11:43 PM
Check out this snipped of the datalog on the setup. A whopping 6.23Amps @ 19.78V average. I'll gear up some more and datalog it again.
http://i189.photobucket.com/albums/z...58-12mmpro.jpg
magman 11.19.2009 10:12 AM
looks nice and smooth...how did it "feel"
snellemin 11.19.2009 10:53 AM
Man the Rustler is so "slow" and I need to gear it up some. The feel of the ESC with the sensor used is very smooth. I take a vid of it in action. Heck as it's setup up now, I can use laptop batteries and still be good with the power output.
snellemin 11.19.2009 03:58 PM
Here's the actual creeping outside my house. I changed the gearing to 58/15
http://www.youtube.com/watch?v=JDN0M1zVnwY
magman 11.19.2009 07:17 PM
it looks and sounds v/smooth.
sikeston34m 11.19.2009 10:04 PM
Was there anything special you had to do during setup?
I'm trying to setup a Novak HV motor with my MM Pro, and it's acting strange.
It will only spin the motor in one direction, and if I pick two wires and swap them, it won't run in either direction.
When running in the one direction, it is very smooth. I don't think the sensors in the motor are bad or anything, but I'm not sure what I need to do.
MetalMan 11.19.2009 10:33 PM
With sensored it's vital you have the main power wires oriented with A B C matching between motor and ESC, because of the sensor orientation. If you need to reverse the motor rotation you should be able to do it from Castle Link.
snellemin 11.19.2009 10:35 PM
I didn't do anything special. I only disabled the voltage cutoff and have my timing on 10 degrees. Are you using the sensored mode only?
sikeston34m 11.19.2009 10:36 PM
I have tried both smart sensored and sensored only mode.
I'm working with it now. I'll check the A,B,C Orientation.
snellemin 11.19.2009 10:40 PM
Yea I forgot about the ABC's.
sikeston34m 11.19.2009 10:47 PM
Got it! :yipi:
I completely forgot about the ABC thing. Running sensorless stuff will spoil ya! LOL
This thing is amazing though. Low speed is very precise! But it will blast off like a rocket when you stab it.
Cool! Very Cool.
Thanks alot guys! :yipi:
Which sensored mode is best? Anyone try cheat mode yet?
snellemin 11.19.2009 10:50 PM
I tried cheat mode a few times in a straight line. Worked good. But the onroad guys will have more use out of it.
