Confused about wheels and tires
I'm searching some new wheels + tires for my LST, but I really don't know which one I should choose because I don't know which tires fit which wheels. From Losi (and some others) I know that they use 'series', 420 series wheels will fit 420 series tires of course (thats easy). But how do you guys know that (for example) a Imex tire fit another wheel? I like these tires: Click But there isn't any info about those tires, no series no millimeters no nothing...
So my question is; how do I know which tires fit which wheels? Thanks, Patrick |
Those seem to be stock older maxx size tires- Imex is pretty good with their info- each tire is in a different size class (highlighted in bold as you scroll through the various different designs), and when you look at the rim choices, you see the same size classes:
Hmm, ok, that is indeed pretty logic.
Neil, do you know some rims for the Imex Claw Dawgs with 17, 20 or 23mm hex? Because Imex Jumbo rims are all designed for 14mm hexes... |
P-L has 14mm,17mm,23mm for MT's. Only Losi has the 20mm rims. |
Yeah, Imex love the 14mm hexes abit too much... :no:
Imex 'jumbo' tires will fit perfectly onto ofna titan & twinforce/madforce rims that have a 17mm hex. |
| All times are GMT -4. The time now is 03:23 PM. |
