look for a good dremmel for x-mass
Building a x-mass list and need a good dremmel....I saw these at harbor freight...what do you all think? Is there another one you all recommend? Also saw their accessory kit as well..
http://www.harborfreight.com/cpi/cta...emnumber=92880 http://www.harborfreight.com/cpi/cta...emnumber=40457 http://www.harborfreight.com/cpi/cta...emnumber=93243 Also found this one...with this set up http://www.amazon.com/Dremel-395-350...8657819&sr=1-3 http://www.amazon.com/Dremel-220-01-..._bxgy_hi_img_c |
I got a "tool shop" brand for $30 WITH a huge accessory lot and WITH the flexible shaft. (you gotta switch to the flexible shaft, no more hot tool in your hand{Linc? is this thing on?})
It was at menards and still running strong with LOTS of hours on it. |
Thanks Harold...I will look it up
i agree on the flexible shaft is great, also as far as harbor freight and chicago tools, the quality is not that great especially on their bits and attachements. if you opt for the chicago tools dremel, use dremel bits as the one that come with it are pretty much junk. and dont expect much battery life out of the cordless as they use low quality parts and batteries. but if u are looking for a more affordable solution i would go with the corded model and use dremel bits.
no cordless on the dremel. baaaaad
I bought this one above ^ about 6-7 yrs ago and still works great ! Lotsa power and great qaulity and a amazing deal for the $$. |
menards has the tool shop one with continuously variable speed and 40 attachments for $12.99
http://i288.photobucket.com/albums/l...b565985_20.jpg |
Wow...cool, thanks!
| All times are GMT -4. The time now is 11:59 AM. |
