Why didn't it die?
Was running and jumping down at the park today(grass). I hit a jump and landed badly and it did over 10 cartwheels on grass. Run down, flip it over - nothing. Guess the connectors unplugged. Open the lid, the connectors are together. Then I see the negative bullet on the MMM is unplugged (V2). With the bullet loose I tried to disconnect the battery and all of a sudden the neg. plug touched one of the motor bullets and a spark flew up.(no smoke) Then I started thinking where should I order my new MMM and if CC will replace my V2.:oh: I carefully unplug the batts and also the motor connections. Then, with even more care I plug the lipos back in(thought it would catch fire:intello:) and the lights come up. Plug everything back and it's working normal.
I was running 6S. Here's what happened to the plugs that touched: http://www.shrani.si/f/2D/9c/4MqvCMNx/1/dscn1101.jpg http://www.shrani.si/f/3F/Kx/3fD9E8x1/dscn1102.jpg Now, shouldn't it be dead from the hit? |
Maybe a little luck and good build quality. :yes:
I ran a MMM V3 on 10S by mistake until it thermalled. I go get the truck to investigate and see the mistake I made. Plug two 5S in series. :whistle: Other than the TVS that is probably blown, the ESC still runs like a champ. They are tough devices.
What battery pack were you running ?
batteries survived just fine however :) |
Funny thing is that my Accucel 6 died when I wanted to charge the second battery.:sarcastic: (resets when it starts to charge) |
Sheer luck, and hard-as-nails esc :yes:
| All times are GMT -4. The time now is 09:50 PM. |
