-   -   Proline 30 series rims and tires (https://www.rc-monster.com/forum/showthread.php?t=24632)
scavind 11.22.2009 02:31 PM
Will these be big enough for the maxx. I'm not sure about how large these will be for my maxx. I hear they're around the same size as the stock maxx tires is this true?
Bondonutz 11.22.2009 03:02 PM
I think the 30seriess are realitively the same as normal 2.2 tires just the wheel is larger with the tire having a lower profile.
The tires are much thinner designed for 4-6lb trucks not a MAXX, They also are designed to be driven on a 12mm hub or a pin on 1/4"-3/16" axles, The Maxx runs on 14mm or larger hubs with 8mm axles shafts. SO, bottom line your shit out of luck,Sorry.
chrismechanic 11.23.2009 03:15 PM
rims and tyres
hi all...i have a mate who has 30s rims on a 10 lb truck and the hexes keep going round. i personally have a 3906 maxx and find even the best of tyre glues will come off with brushless so i use maximizer beadlock rims and proline tyres. check out the half inch offset swee trims
bye all...
