info tekin motor T8 2250kv
WISH TO KNOW SOME INFORMATION for motor T8 tekin 2250kv:
- VOLT MAX = ??? - TEMPERATURE MAX = ??? - RPM MAX = ??? - PIGNON AND SPUR GEAR MAX FOR TRAXXAS E-MAXX OLD VERSION = ??? |
use this calculator to estimate speed and gearing...it will also show you rpm's related to your chose gearing...http://www.scriptasylum.com/rc_speed/index.html
plug in the variable and it will help you out. As far as temps go..we all like to keep motor temps below 150. Not sure on max. voltage |
I'd run it on 4s primarily, step up to 5s for when you need more power. I'm sure it could handle 6s but that's a lot of RPMs. Max temp is somewhere between 180 and 200 but I always stop running at 160 to stay on the safe side. I'd keep the RPMs under 45,000 but I'm sure the motor can handle more.
X magman:
I do not scrptasylum. unfortunately it is not real. X Unsullied_Spy: tekin http://www.teamtekin.com/hotwire/ESC...up-sheets.html says here max 4S lipo for 2000kv (2250kv) trugghy. I misunderstood? |
If they say 4s maximum, I'd stick to 4s maximum.
I can not understand anything. look here http://www.rctech.net/forum/electric...ml#post6637024
What is the maximum voltage? Randy Pike is what he writes? or what is written in the site tekin? |
uppp
English isn't galaxy76 strong suit but here are some tips if you can understand:
Max voltage: Possible to use 6s but not recommended for longevity of motor. 4s-5s is acceptable. Max temperature: No more than 70C after 15 minute run Max RPM: If you are worrying about this then you have other issues in your vehicle. Gearing: Gear ratio will be DIFFERENT DEPENDING ON YOUR APPLICATION. This link will allow you to calculate top speed http://www.scriptasylum.com/rc_speed/_top_speed.html For E-maxx I suggest start with max speed of 30mph. If MOTOR, ESC or BATTERY gets too hot then reduce top speed by changing gear ratio. |
grazie :)
| All times are GMT -4. The time now is 11:39 AM. |
