-   -   CM26 motors (https://www.rc-monster.com/forum/showthread.php?t=24689)
Maciolus 11.26.2009 02:07 AM
CM26 motors
Look what I found on CC website:
http://www.castlecreations.com/produ..._pro-cm26.html
Good work Patrick :yipi:
crazyjr 11.26.2009 11:03 AM
The info in the rc18 is incorrect, the gear is in fact a 48 pitch gear. As far as i know the duratrax is the only ones i seen with a metric gear, you can get the Robinson metric 48 pitch for tamiyas through tower
E-Revonut 11.26.2009 10:07 PM
Actually the RC18 series does use .5mod. IIRC Novak has the pinions needed as the 1/18th system they made has a 1/8"(3.2mm) shaft as well
ta_man 11.29.2009 02:02 AM
Where did you get that incorrect info you take to be a fact when its not?
