-   Slipperential discussion (https://www.rc-monster.com/forum/forumdisplay.php?f=45)
-   -   Is there normal for the drive cup to wobble abit? (https://www.rc-monster.com/forum/showthread.php?t=24692)
superek4 11.26.2009 06:48 AM
I notice my slip diff's drive cup wobbles(can move up n down like 1-2mm) so I took it out n check the cups. Hv not open it yet but is it wear n tear? Must I change the cups?
The bearings is still ok.
RC-Monster Mike 11.27.2009 03:33 PM
If the diff outdrives are wobbling, it sounds more like the endcaps are worn. 1-2mm of play is pretty excessive movement. I grease my outdrives and haven't worn out any caps, but I do have steel endcaps available as an option parts - they are about 2x as heavy as the aluminum caps, but are hardened steel and should last pretty much forever. :)
wallot 11.27.2009 04:26 PM
Mike, whats twice as heavy in grams? (or ounces or any other medieval unit you keep using :whistle: )
RC-Monster Mike 11.28.2009 01:23 AM
The front and rear cap made from steel weigh a total of 30 medieval gram units(1.06 medieval ounce units). The stock parts weigh a total of about 10 medieval gram units, so the steel parts are actually 3x as heavy(just weighed the parts) . :)
_dV 03.22.2010 04:22 AM
medieval what now? what is the weight of the whole slipperential? (preferrably 46t mod 1 with both steel endcaps, incl bearings if it's easier)
also, what is the total width from outdrive end to outdrive end? ..cheers
