Dying parts
Well I wanna murder out my pede.. Starting with the new VXL pede chassis i got.. I've seen people dye their plastic parts.. What kind of dye do I use?.. i also plan to dye my shock cylinders and tranny housing and bulkhead(s).. is there any specific method to do this?.. and where do i find the dye at? i want to dye it black if you didn't catch on.. can anyone hit me with a price off the top of their head also please? wat should i watch out for? Thanks in advance..
(p.s i used the search also came up with nothing..) |
RIT DYE....liquid form. can be found at grocery stores, craft stores. What I do is heat up water to just before boiling point, add dye ...up to 3/4 bottle..stir WELL. ( Add a tablespoon of white vinegar as well..it opens up the pores of the plastic better supposedly.)...submerge parts in solution...the longer you keep the parts in the solution, the darker they will be. I stir solution every 20 mins. or so as well. I generally leave things in for up to 1 hr. depending on what I am doing.
Good luck! A bottle is about $4-5 Here are 2 pics. of rims that I have done... http://i271.photobucket.com/albums/j...jalbee/049.jpg http://i271.photobucket.com/albums/j...e/DSC01918.jpg |
would anyone be willing to get some for me and send it to Singapore? We don't have RIT over here.
RIT is just a brand name- any decent clothes dye will work perfectly, just use the liquid stuff to get a good even solution, though the powder stuff should also work well so long as its stirred well to dissolve it.
In Singapore, we only have powdered Dylon dye which have not worked well.
or just get older (pre xl-5) rustler parts that are already black?
Maybe try ebay?
thanks guys ill just try the dye
Anything blacked out looks bad ass!
Hahahahaha |
100% truth on that!!:yes: |
Just for Shits and Giggles I thought I'd look at the website.
You can order directly from the Co. ? http://www.ritdye.com/Buy_Rit_Now.28...CC9FXgOH2D7F2B |
Its not so much rit dye, just the pulleys, the SPX case, and spur. Black ano. black wire. You get the point:mdr: |
| All times are GMT -4. The time now is 11:29 PM. |
