Question for Pdelcast
Since the Castle 1717 motor's shaft size was incorrectly stated, can my wife send mine back to swap for a 1520 1Y with a 5mm shaft, and get the difference in price credited back? This was suppose to be my Christmas present that will be used for a Christmas build. I have no 6mm pinions nor do I want to buy any. Do you have enough stock left of the 1520 1Y that I could get one before Christmas?
if he doesn't chime in i'd try castle direct on monday
phone: (913) 390-6939 • fax: (913) 390-6164 • e-mail: info@castlecreations.com |
I can't check stock status from home -- so I don't know if we have enough 1520s, but if not, I'll see if I can dig one up for you. We stole a few (still in box) for engineering... Thanx! Patrick |
Now that is good service...
Hopefully the 1717 rotor is similar sized to a kb 45 rotor, that way I can use the adapter that I made to have the machinist turn the shaft to 5mm... |
Good customer service indeed.
Thanks Patrick !!!! My wife will contact Christy in the morning, and arrange everything.
Thanks again Patrick !!!!!!!! Everything went smooth as silk.
| All times are GMT -4. The time now is 02:13 AM. |
