making mamba monster waterproof
will outerwears work?
I pulled mine out of the case and plasti-dipped everything except the heat sink. I've only run it once so far but it worked just fine.
here the best way to make it waterproff, i would make it next week with my mamba, with my receiver, with my servo...
http://www.youtube.com/watch?v=LUSmKAvHyEk |
Problem realy is receiver plugs, you need to put electric grease or something like that to connectors to prevent water from making interference. Its gonna look messy after that.
"Problem realy is receiver plugs, you need to put electric grease or something like that to connectors to prevent water from making interference"
It's a good idea but unless you bash in an old golddust mine probably unnecessary, I waterproof my boat ESCs and RXs by totally encapsulating them with just flying leads and watercooling pipes sticking out (not good for the air cooled MMM) I have come in from several races to find a hole/split in the hull and the inside filled with water with all the electrics and wiring/plugs submerged, no grease on the plugs and its all been working just fine, just slower from the motor/coupler spinning under water and the boat weighing twice as much as normal. |
I stick blu-tack around the rx plugs to block dust. I don't see why it can't be used for keeping water out. Easy to put on/off and a shite load cleaner than grease.
| All times are GMT -4. The time now is 09:07 AM. |
