Mamba 25
Hi, I just finished downloading 3.22. Updated my 1/10 Sidewinder,MM &MMM. When I plugged in my Mamba 25 it didn't "see" it. Does it need to be sent in? Thanks,Don
Do the lights come on?
Also, did you perhaps remove the red wire to use an external BEC? If so, the red wire needs to be there...
No lights and the red wire was not removed. It does work-it is currently configured to run brushed motors. Don
Stupid question, but are you plugging in the link correctly into the throttle cable? If it's the linc style that has the three bare pins, try flipping the throttle connector. If it's the wrong way, the ground and signal wires will be swapped.
I plugged it in the same way I plugged in the Sidewinder and the MMM-they worked-I'm puzzled! Don
| All times are GMT -4. The time now is 05:06 AM. |
