-   Unlimited Engineering (https://www.rc-monster.com/forum/forumdisplay.php?f=28)
-   -   WEll the gears fit (https://www.rc-monster.com/forum/showthread.php?t=2495)
coolhandcountry 03.05.2006 09:48 PM
WEll the gears fit
I have the ue 6 spyder diffs. I want to swap out the pinion and spur with a hot bodies. Do I need to change the diff housing or just the pinion and spur?
squeeforever 03.05.2006 09:54 PM
do you mean the pinion and ring gear? im pretty sure that you can use the same cups.
coolhandcountry 03.05.2006 09:58 PM
yeah squee. The ring and pinion. some call it spur some call it ring. but the one that goes to the diff housing. I want to make sure before I get them.
squeeforever 03.05.2006 10:25 PM
im pretty sure they will because if im not mistaken they use the same cases.
coolhandcountry 03.06.2006 07:52 AM
Thanks squee. I may have to order the ring and pinion and see. I have to let you know more on the trial fit.
Serum 03.06.2006 12:11 PM
That is doable Coolhand, they use the exact same diffcup.
You need another gearing with the 2250?
