-   -   large mod 1 pinions (https://www.rc-monster.com/forum/showthread.php?t=25032)
mikey84 12.21.2009 01:27 AM
large mod 1 pinions
where can you find 5mm mod 1 pinions that are bigger than 26t?
bdebde 12.21.2009 01:52 AM
Kershaw designs has some, but they are plastic. SDP-SI also has some in many materials, but nothing hardened.
simplechamp 12.25.2009 02:18 AM
What is your gearing situation? Is a smaller spur out of the question?
mikey84 01.05.2010 02:20 PM
looking for what i can get for gear ratios for Lst xxl
lincpimp 01.05.2010 02:40 PM
A few options:
You can use a tdr colleted adapter and run the thread on gears Mike sells in the rcm store, use the 2nd speed gears.
You can also use the 2 speed adapter that mike sells, but you may have issues with the gear unthreading when you brake or reverse.
Go to sdp-si and try to get something that will work. Stainless will be your best bet, but you will have to use the plastic 63t spur as those gears are not hardened.
lincpimp 01.05.2010 02:44 PM
Only thing sdp-si has in stainless mod1 with 5mm bore and set screw is 30t, then 36t. Not sure if a 30 will work for you. The tdr colleted adapter and Mikes hardened gears is about the only game in town over 25t... I have had good success with the 25t pinion and 63t spur. If you want more speed you can always go with taller tires! Losi also makes a tin coated 59t spur, but you may have issues getting close enough mesh with the tdr mount.
jhautz 01.06.2010 03:29 PM
another option is a higher kv motor if you cant gear tall enough.
mikey84 01.07.2010 01:25 AM
i am using mikes 2 speed adapter now it works great
and i have a higher kv motor but im trying to put my lower kv motor into it
