-   -   Motor RPM Reverse Direction (https://www.rc-monster.com/forum/showthread.php?t=25049)
jetbill 12.22.2009 09:08 AM
Can someone confirm regardless of how a 2200 with a MMM is wired the motor rpm will be the same? Read somewhere that reversing the motor will generate 2050 +/- rpm..
Can't see how this is possible, but would like to confirm.
brushlessboy16 12.22.2009 09:44 AM
Dont qoute me on this but i beleive that that is for motors that are timed for a certain rotatio(brushed motors that are made to run cw, or ccw). Im pretty sure it does not apply to brushless motors
BrianG 12.22.2009 10:48 AM
I think you're right BLboy.
bruce750i 12.22.2009 11:13 AM
Yeah, without a given voltage this sounds like a myth. We need a R/C version of Myth Busters for matters like this.
BrianG 12.22.2009 11:17 AM
Hopefully a little more scientific approach than the crap methods MythBusters uses though...
J57ltr 12.22.2009 11:21 AM
I have read that Y motors like to run in a specific direction but I don't remember the source so I would like to know if this is true as well.
Jeff
RC-Monster Mike 12.22.2009 12:27 PM
This would apply to a timed, sensored brushless motor being run on a sensored ESC (Novak, for example) as well as brushed motors.
brushlessboy16 12.22.2009 01:01 PM
Since all "timing" is done inside the algorithm of the esc- you would think since most esc's have the option for reverse rotation- that the motors are neutrally timed.
suicideneil 12.22.2009 01:23 PM
^ That only applies to sensorless setups- the novaks and similar motors often have adjustable endbells that you can advance; the endbell houses the hall sensors that determine when each phase fires, and are seperate to the phases themselves. Sensorless motors have the timing dtermined by the esc > no hall sensors.
