-   -   Once I buy a UBEC, do I still need a RX switch? (https://www.rc-monster.com/forum/showthread.php?t=2506)
Superemaxx89 03.07.2006 11:09 PM
My MX-3 came with a on/off switch for my RX system. If I buy a UBEC, I don't need that switch anymore right?
JOHNNYMAXXIMA 03.07.2006 11:37 PM
No, it's not necesarry (the switch). You will just have to keep unpluging the UBEC from the receiver though, so I just kept my switch.
nbcaznmaster 03.08.2006 06:24 AM
same herE! i rather have switch on
MetalMan 03.08.2006 08:31 AM
If you solder the UBEC to the controller's input wires, then you can just use the battery connector as a switch.
coolhandcountry 03.08.2006 01:39 PM
You don't need the switch. I find some times i like it some time i don't. Either way if you let the truck set for a while you have to unplug the batteries.
