-   General Nitro (https://www.rc-monster.com/forum/forumdisplay.php?f=13)
-   -   Surefire .32 pull start uncoiling while driving? (https://www.rc-monster.com/forum/showthread.php?t=25099)
Koko 12.26.2009 10:39 PM
I'm a brushless guy, but my cousin is a nitro guy. He bought a Losi LST2 with a Surefire .32 motor in it. Now, everytime he tries to drive it, his pull start unravels.
Any idea what would be the cause?
brushlessboy16 12.26.2009 10:42 PM
bad one way bearing or the spring came loose
Koko 12.26.2009 11:10 PM
Even if the engine is new?
_paralyzed_ 12.27.2009 12:11 AM
yep, even if new. All it consists of is a spool of cord, a coil spring and a one way bearing. It sounds like the one way is dragging, or the spring is weak, or something is gummed up and dragging. Take great caution when removing the recoil so the spring doesn't fall out, or you are screwed.
Sounds like a good time to upgrade to roto-start.
BTW: surefire and axial .32's are identical internally. I saved $20 buying a piston and sleeve for my surefire by buying an axial unit.
