Wiring for a BK120
I did search, but I did not find exactly what I was looking for. I am wiring my BK120 and it has two black/two red wires on the battery side of the ESC. Do the two blacks just get wired together on one side of the Deans connector? Then same with the reds and that would complete the male side of the Deans?
There are six wires on the motor side of the ESC. I am assuming two wires for each of the three motor phases. So, two of the ESC wires need to get connected to one of three motor wires? And then so on until I am done. Thanks for the help and clarification. Matt |
Yes, you are right. Just treat the double wires as if they were one.
Thank you for the help.
Matt |
Would I be correct in assuming that if I wanted to parallel two battery packs I would just need to put a deans connector on each set of red & black wires? Then plug into the two seperate packs.
I am sorry for jumping in on the string, but I am a new guy waiting for the 8xl to get in. I have the 12020. Can I ask a question so I set it up right. The two black wires go on the negative of one deans connector, the two red go on the positive on another deans connector. Do I then run a wire between the + to + and - to - of the two connectors? Will deans battery wire work? Any one with a picture? Thanks!
you run the jumper wire from the negative to the postive of the other dean.
There are some pics around here for it |
Once someone has completly wired their 12020 (or other doubled up wire controller) can you post a picture? Thanks.
Here is what I think it should look like:
http://img73.imageshack.us/img73/5786/yharness0bg.png Hope this helps! Brijar!!! |
wow. that is a good drawing!
Thanx again, Brijar!!! |
Wow! Awesome picture Brijar! Thansk for the work....that is crystal clear!
Would you all use deans battery wire for the jumper? |
Yes, W.S. Deans Wire is very nice and an excellent choice. If you have to use wire for anythin RC related, use Deans wire unless it is small wire such as receiver wires and servo wires.
Brijar!!! |
Kool keep this drawing UP It would help alot of people.. Thanks It helps me too.
thanks Brijar... :) |
There was a pic on the forum. I want to say it was posted by papa. It showed where the black jumper was.
| All times are GMT -4. The time now is 06:10 PM. |
