Airtronics MX-3 FHSS 2.4GHz
anyone on there own this radio ? I like it but I never resolved the issue with the reverse was alot faster and more powered then the upfront throttle I tried to reverse the motor wire nothing .. tried to change the motor direction setting in the MMM still nothing .. tried to to change the throttle mode on the radio and nothing again ... I have no idea..
Flip the differentials in your truck...
I have that radio, 5 tx too. When I use Mamba Max's I have everything to 100% then after its done I open the throttle to max ..120% ? its like extra super charger
Recalibrate it. You might not of pulled full throttle when you calibrated it so its only going as far as its been programed to go. I did this with my slash, major pain and very frustrating. When through two brand new motors to find out this was my problem.
I run this system and have no issues with the MM or MMM Everything is at 100% and the throttle is normal but my steering is reversed.
Jeff |
I tried to Recalibrate it and still the same it does the same thing on my other rc with other same 2.5 airtronics receiver aswell :sarcastic:
| All times are GMT -4. The time now is 06:05 AM. |
