antennas on spektrum rx
Just took the plunge into 2.4 and was wondering if you guys extended the antennas a little on the rx to mount into a tube or just let them as is
Special type wire, don't even look at it.
No need to extend, leave as it is.
so where do u guys put the wire? does it need to be placed in a special way?
Ok I will leave it as is...
Coil it up with a small diameter tool like a screwdriver and just leave it as a little pigtail under the body. It's short enough that if you give it a good tight coil, it'll stay put without issue.
You need the wire to stick up at least 1 inch for optimum performance. I usually use a radio box or a mount that also has a antenna tube holder, then just cut a short piece of antenna tube to hold the wire. I leave it under the body, so it stays safe if I flip over.
I keep all mine inside the radio boxes- no problems thus far
| All times are GMT -4. The time now is 01:02 PM. |
