-   -   mmm with 6s lipo (https://www.rc-monster.com/forum/showthread.php?t=25196)
at106 01.04.2010 02:59 PM
mmm with 6s lipo
Im currently lanning on building a brushless 1/8 buggy. I was looking to use the 2200kv motor so i could run 2x3s lipos in series to make it a 6s. But now im thinking this could cause problems so would i be better off using the 2650kv motor and just using single 3s batteries or 2x3s batteries in parallel to give extra run time? Some of you will probably be asking why i dont use 4s lipos thats because i use only 3s lipos for my rc helicopters so ive already got plenty of them.
bruce750i 01.04.2010 03:46 PM
Should be fine if the lipos are up to the task, you don't mind charging two lipos, geared correctly and have a series connector. IMO better than running the 2650 on 3s. I only buy 2 and 3s lipos you can re-configure for all the rest 4s, 5s & 6s, uses a smaller charger and power supply too.
bdebde 01.04.2010 04:11 PM
The MMM 2200 combo on 6s is very powerful, if it is for a basher it should be fine. If it is for a racer, you may want to consider different voltage or different motor.
Semi Pro 01.04.2010 09:02 PM
lol for racing you are better off with the 2650 on 3 or 4 cell
i am running a 1400kv T8 in my buggy on 6cell and it is just stupid fast, a 2200kv on 6cell would just be useable power.................like dbedbe said, perfect for bashing:yes:
at106 01.05.2010 12:06 PM
Thanks everyone, im only bashing so ill go ahead with it.
bruce750i 01.05.2010 06:33 PM
What size chopper do you fly? I've been trying to learn to fly one for the last couple years.
at106 01.06.2010 04:54 AM
I fly a trex 450, im only a beginner and its not easy.
DCastaneda 01.06.2010 03:10 PM
Don't 450's only use small capacity lipos (<2500mah)? Don't know if your packs will be up to the task unless they're very high quality cells. Even then, runtimes will be short. Saving money by sharing lipos between vehicles is a great idea, but the 2200 requires more amperage than your current lipos can dish out IMO.
at106 01.07.2010 11:10 AM
Looks like your right! Time for a new plan.
DCastaneda 01.07.2010 06:22 PM
Yup, the last thing you want is to fry some perfectly good heli packs :na:
