Novak HV6.5 motor with Tekin RX8
Would this setup work? I'm a little worried that the D2 drive which swicthes to sensorless at high speeds, would this burn out the Novak motor?
Cheers |
it will work fine:yes:
I would actually think that it should work better than a pure sensored setup. The sensorless mode is constantly adjusting for the best motor performance and only uses the sensors for a consistent start up.
You should have no problems. |
Alright thanks
How about one of these motors on a Velineon ESC and plugged into the sensor port. Will it be ok??
We are combo-ing our Havoc Pro controller with the Hv Pro motor (4.5 I think) for one of our customers for use in a short course RTR on 2S.
Hmm, I may have to look into a HV 4.5 on my MMP for my Slash 4x4. I was thinking the HV 6.5 on 3S, but if the HV 4.5 runs well on 2S, I have more of those batts than I do 3S. |
on 2s its close to a 10.5/9.5 in top end, but it has alot more torque, on 4s it sounds like a Fing jet engine:whistle: |
Will the VXL ESC control the 4.5HV motor ok??? And can I plug in the sensor to the sensor port of the VXL ESC?? I want to use this on a Hyper Mini STe.
Thanks |
Whitrzac...Thanks
Maybe I should have stated that I will be running 2S with the VXL. I do have the fan but they say that there is no motor limit on this speed control just it has a limit of 3S. I was wondering about the sensor being plugged in, due to the fact that I heard somewhere that there could/have been issues with this and was wondering if anyone has any first hand accounts on this. Thanks |
It's ironic the HV motor never really worked well on 4S in heavy trucks and was discontinued, and now is the BEST solution on 2S in lighter SCT's and you can't find them! |
| All times are GMT -4. The time now is 06:05 AM. |
