Strobe Slipper
Anybody know if the stock gear cover will fit on the strobe slipper?
In diameter it should be okay, i don't know about the thickness...
Looking at this pictures make me think it will. You can use normal nuts and lock them with red loctite to save some space. http://rc.stuurmijmail.nl/Emaxx/FLM%...d/slides/4.JPG |
it will fit but mine wouldnt because of the 20t pinion.
Why run the 32 pitch when you can run the stronger mod 1? If you need help with same ratio or something let us know.
I haven't gotten the cover to fit (it will go on, but there is slight rub). I haven't used the gear cover in years, though.
I thought about cutting the front part out so the gears are covered but you can see them still. But that was just and idea. Help keep the wires out but it may hold som rocks in around it.
| All times are GMT -4. The time now is 12:42 PM. |
