-   -   Cutting and drilling a Hyper 7 chassis. (https://www.rc-monster.com/forum/showthread.php?t=25334)
Bazzokajoe 01.12.2010 03:49 PM
Hey guys,
just looking for a few tips on cutting my chassis,
as most of you guys probably already know the chassis is 7075 aluminium
i am intending on cutting another hole for my spur gear, as in flipping my centre differential around,
as this will give me two possible places to mount my motor (behind the servo or next to it)
I have access to a pillar drill and dremmel but no milling equipment, i am intending it to look good, or at least neat :P
if you dont really get what i am trying to do just say so, i re read that and i cant even understand it :S
Bondonutz 01.12.2010 04:50 PM
If your intent on making a slot in the chassis, drill the inside perimitter of the hole with a 1/8" drill bit till the chunk falls out and finish with a metal file. Shouldn't take but 15-20 miutes and a couple beers.
JThiessen 01.12.2010 09:08 PM
Scribe your lines on it with a utility knife, then use your dremel to cut as close to the lines as you can. Then use a fine file to finish the slot. You can also just use a drill for the extreme ends of the slot (use a drill the same dia as the slot is going to be).
I use these wheels on my dremel - works much better than the standard ones. http://www.amazon.com/Dremel-EZ456-2...3344771&sr=1-4
They also come in a kit
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7
thzero 01.12.2010 10:25 PM
Those are the ones I've used to cut aluminum. I have also found the version for plastic works well on thick lexan bodies.
Originally Posted by JThiessen (Post 343791)
_paralyzed_ 01.12.2010 10:44 PM
:surprised: That's almost $2 a wheel!!! Do they work that much better?? I know I hate changing wheels, so the convenience is definitely a plus.
JThiessen 01.12.2010 11:00 PM
In a nut shell - yes. I used to go through 2 or 3 wheels per cut job. Now I change wheels about every 4th or 5th job.
E-Revonut 01.12.2010 11:11 PM
However you do it make sure that you drill a hole in the corners. 90 degree corners are weak spots asking for problems, plus the radiused corners look better. It's not a big area that needs to be removed so if it was me I would drill two holes, one at each end of the slot, pick a bit that is slightly wider than the spur gear and then use a dremel to remove the material between the holes
_paralyzed_ 01.12.2010 11:59 PM
sweet, thanks:yes:
BrianG 01.13.2010 12:23 AM
+1. That's exactly what I would do...
Bazzokajoe 01.13.2010 03:02 AM
cool cheers guys :)
now i have another question... when converting to electric do any of you fill in the nasty nitro holes (flywheel/engine mounts?)
if so... with what?
_paralyzed_ 01.13.2010 03:52 AM
Originally Posted by Bazzokajoe (Post 343842)
cool cheers guys :)
if so... with what?
I have never seen the holes filled...........
Bazzokajoe 01.13.2010 09:54 AM
ahh ok, i just thought it would probably look alot better , i guess i will see next week, when all my parts are supposed to be arriving :)
Fast5sRevo88 01.13.2010 04:39 PM
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7[/QUOTE]
Are these better than the fiberglass reinforced ones?
JThiessen 01.13.2010 08:04 PM
I'm not certain which ones you are referring to? I've only used the ones I linked to and the standard little brown ones that come with most dremels.
Fast5sRevo88 01.13.2010 08:32 PM
I was referring to the ones that are about 2" round, they are brown, but they have a fiberglass webbing on them.
