-   Novak (https://www.rc-monster.com/forum/forumdisplay.php?f=42)
-   -   NOVAK HV 4.5 Motor shaft seperated (https://www.rc-monster.com/forum/showthread.php?t=25369)
HV-Hyper7 01.15.2010 01:36 PM
Does anyone know what sort of glue or epoxy i can use to put the magnet back on the shaft in my HV4.5? not sure why it came appart as i never got a temp reading above 120? anyway, would JB Wled work?
Thanks for any advice you might have.
HV-Hyper7 :oops:
suicideneil 01.15.2010 02:00 PM
Red loctite, the high-temp version would be best I believe.
J57ltr 01.15.2010 02:04 PM
Red Locktite is a little weak in this application. Use sleeve retaining compound you can pick it up at the autoparts store.
http://www.permatex.com/products/Aut...e_Retainer.htm
Jeff
HV-Hyper7 01.15.2010 05:37 PM
Thanks guys, i will look into the sleeve reataining compound. any tips on putting the two back together other than make sure it is in the correct place on the shaft?
Chris
suicideneil 01.16.2010 08:39 PM
Nah, just make sure its not too far forward or back like you say, and make sure you let it dry fully before using it again- keep the magnets away from anything metalic too... :lol:
brushlessboy16 01.16.2010 08:56 PM
I use two part epoxy
himalaya 01.19.2010 03:37 AM
Loctite 603, 638, 648, green magic drops. that's what we use to glue flex shaft into hard steel propeller shaft, unbelieveable strenth and shock resistance. It works only for tight matching metal parts, ideal for motor shafts.
crazyjr 02.11.2010 10:39 AM
Sorry i didn't see this sooner, i used JB weld to put a bonded rotor back on a shaft in a hv 4400 motor as well as a 1200XL basic lehner. No longer have the hv but the 1200 still runs fine after two years
