Large scale fabbed straight axle monster
So I have decided to undertake a larger project here! Spurred on by Nickrummy and his ultra gangster (yes it is that good!) 1/6 scale silverado, I have decided to make something using the big ole bodies that Gee sent me way back!
I have a avalance, navigator, H3 and something else that I cannot think of... Most likely go with the Navigator, cause it is just massive, and I like fords... Something like the txt chassis looks good, and simple. Maybe some savvy big bore shocks as they are big and have long stroke. Trans will likely be a new emaxx tranny with the 2 speed setup in it. Low 1st gear for crawling and regular 2nd for some speed. I have a 2826 axi outrunner that I will use with a MM or MMM and 4s lipo. Plenty of power from what I have seen, or I will go up to the 4130 I have (sick power, it will easily break the tranny). The 2826 works well in the 6x6 maxx with a MM and 4s so it should do in this. Now heres comes the crazy part. I plan to make my own axles! All steel, with lst diffs (what else!!!). Not sure what width I can get with lst2 cvds, but I plan to try for something like 14" wide. I plan to run a striaght rear axle, and use some of the hyper cnc knuckles for the front axle. I will run behind the axle steering and probably use revo sliders as center driveshafts. As for tires, I really like the inflatible idea Nick had, so I may give that a try. I also have a set of 40 series boggers (rc4wd?) and axial beadlocks that I can run for more serious crawling. So the axle design will be first. I plan to use tube and flat steel to make these axles. I will weld everything. These will be trussed for strength. The lst diff cases will be easily removable, just like they do in a lst. Most likely have them come out the pinion end of the diff. Should be pretty easy to make, especially the rear straight axle. Will likely stick with 17mm or 23mm hexes. I cannot remember what the beadlocks have, pretty sure they are 17mm. I also have a set of proline 40 series beadlocks and they are 23mm. I will get some mock up pictures and dimension info asap. Just need to get my house finished and on the market. |
Sounds like a cool project James...seeing as I weld, I will be curious as to your axle fabrication goes. What grade steel are you going to use for these?
Ambitous prodject Mr Pimp, Very curious to see your design on these axles, keep us posted please.
Link and shock mounts will be thicker material and most likely cut to lock into the trusses. All will be welded together quite a bit for strength. I imagine this axle will be a bit heavy, but also stout and I will attempt to use thinner material where possible and not have too much excess. Servo mount will be on one side, setup for an upside-down 1/4 scale servo with the arm facing backwards. Steering linkage will be based on a full size truck, with the servo arm acting as a pitman arm. Another idler arm will stick out in the same location on the other side of the axle, and join the servo arm with a link. Then a link will come off each side and join the respective knuckle. Kinda complex, but it will allow me to get the linkage out of the way of the driveshaft and the axle. Not sure if any of that makes sense, but it does to me! |
It does makes perfect sense...keep us updated
Ok, changed my mind on the lst parts. Thinking that Cen GST parts may be better for the axles. So I will scare up some cvds, diffs, and knuckles. Might end up being cheaper than lst parts too. Plus the cen diffs are supposed to be pretty sturdy...
So you're going to do something like this?
http://i91.photobucket.com/albums/k3...cker-maxx4.jpg http://i91.photobucket.com/albums/k3...cker-maxx1.jpg http://i91.photobucket.com/albums/k3...cker-maxx3.jpg I can't find the other pic of the centersection, but the axle tubes had another washer welded on and the tubes were bolted together with a t/e-maxx diff sandwhiched between. From what I remember it held up very well, he ended up bending all the suspension links, not the axle. I think doing something similar where the tubes unbolt in the center would be stronger, and easier to assemble/disassemble than having a continuous notch for the cvd's and diff to come out of. Just tossing it out there, can't wait to see some pics. |
I really want a 1 piece axle. My design should be stronger than any sort of split axle, despite having notches for the diff to slide in. Mainly looking to make 1 wheel landings repeatable... |
I would love to see some straight axles that can take a poundding like the real thing! A scale version of the axles in a real MT would be cool, think of the abuse they take, 10,000lbs going 50-60MPH and falling from 40'+, thats some serious abuse. They still fail from time to time but that is alot of stress on them.
Can't wait to see teh end product Linc |
Subscribed! If those axles turn out nice I'll take a set :lol:
I would like to see some better pics of how you mounted the links on the x factor axles. I had an x factor a while back, but it was a turd, still have the stock chassis, and shitty tires! |
Why not step up to the next level on your diffs. Seems like like we are almost at the limit of 1/8th scale diffs now. I'd think some of the 1/5th scale rigs would have something beefier for you to use.
| All times are GMT -4. The time now is 03:27 PM. |
