-   -   center diff question (https://www.rc-monster.com/forum/showthread.php?t=25415)
mbx1275 01.19.2010 07:11 AM
1 Attachment(s)
just a quick question how would a direct drive setup go in my ofna ultra buggy?
would it be very effective useful or useless
Unsullied_Spy 01.19.2010 07:35 AM
Depends on what you want your buggy to do. That will make it wheelie a lot more and put more strain on the rear portion of the drivetrain as a result but you won't unload the front wheels under lots of power. That will probably make it push (oversteer) in the corners, so if you're racing it you'll want to keep the center diff. Personally, I'd just keep the center diff and put thicker fluid in it to adjust the unloading unless it is strictly an onroad buggy and you want it locked but lighter weight than a locked diff.
mbx1275 01.19.2010 07:43 AM
im running 30,000w in the diff at the moment heaviest oil i could get australia sucks for parts...
its running losi 2100kv combo and 14.8 5000mah 30c pack if that makes a difference
seems good now ill see how it goes after a few runs
