Balance connector ?
I bought this balance connector to charge my two 2s neu packs as one 4s pack . It says it does kokam,neu, & orion. The description says it's a xh plug. But my balance connector for my 4s neu says it's a eh plug . what do you think ?.
http://www.amainhobbies.com/product_...=Product-Feeds |
I thought we went over this on the phone? :wink: If you zoom in the pic and look at the top, you'll see it says "XH & EH"
Offhand, do know if this adapter board will connect to a hyperion adapter board cable??
He doesn't (I was on the phone with him yesterday), so he's gonna get that board and also a cable specifically for Hyperion. If the board's connector cable won't work, he'll just splice in the Hyperion connector.
Sorry, my ques was about using that balance adapter myself with my Hyperion 0610 charger.
I'd like to series charge 2S and 3S pacs (as 4S and 6S) if this would work instead of having to fabricate a serial balance adapter. |
He said it will so we will see . If it does not work i'll just send it back . |
Brian of the 3 2s plug sockets . I know the negitive socket has to be with the negitive deans plug . But should i use the middle socket for the positive socket or the one on the right side of the board ?.
The middle one would go to the most positive pack.
I got my balance plate today . This plate lets me balance multiple packs as a single pack . This plate does the same thing brian's y harness does . This one does both xh & eh plugs . all i did was trim the socket a little so the eh plug would go in eaiser . I will be balancing two 2s packs as a single 4s pack . Also the stock protek plug goes right into my hyperion 610i charger.
| All times are GMT -4. The time now is 10:35 AM. |
