-   -   lipo question (https://www.rc-monster.com/forum/showthread.php?t=2555)
nl12 03.15.2006 03:43 PM
lipo question
I am buying lipos for my brushless Jammin CRT with lehner 2240
I will be using 8s lipo
I will either buy 3700mah 20c packs 74A constant 111A burst
or 4800mah 20c packs 96A constant 144A burst
I want to know if I will see any performance difference besides runtime by going with the 4800s
squeeforever 03.15.2006 04:29 PM
i dont really think so except for longer runtimes.
Serum 03.15.2006 04:37 PM
What cells are the 4800's?
nl12 03.15.2006 04:43 PM
New kokams via FMA Direct they will be avalable the 20th of March
Serum 03.15.2006 04:45 PM
then 4800's it shall be! just look at their size, they might be too big for your conversion, i don't know..
nl12 03.15.2006 04:48 PM
They will fit, but will the extra amps give me more speed, punch, or anything other than runtime?
coolhandcountry 03.15.2006 04:57 PM
Well if they fit and the money is very little I would go with the 4800.
nl12 03.15.2006 05:07 PM
$250 vs $170 each, I am not skimping on this truck but if runtime is the only difference would rather buy the 3700s and buy more packs to switch between, but if my system wants to pull a lot of amps I want lipos that can deliver, problem is I have no idea how many amps the 2240 will pull. If it is greater than 74A I will get the 4800s if my setup will never pull that many amps then I will get the 3700s (or if there is some other benefit besides runtime that I dont know about). I am mainly considering the amp delivering ability but I dont know if I will see a benefit on my setup.
Serum 03.15.2006 05:09 PM
that is quite a price difference.
Promod uses the 3200's on his 2240, it can take SERIOUS power from the batteries, but that are small peaks.
The 3700's will serve you right and be lighter as well.
nl12 03.15.2006 05:15 PM
Benefit of the 3700 lighter truck heavier wallet!
I wonder which truck would win in a drag race to 60mph everything else equal except lipos?
Serum 03.15.2006 05:20 PM
Lol, Yeah..
Well, the 4800's can put more current out on paper. But at what voltage is that? you need to know more about the cells then.. Hard to tell.
The flightpowers are very good, from what i've seen in Viruss his eagletree recordings. their voltage stays rather high.
One other thing NL, you don't need to reply the entire quote if you reply in the thread, okay?
I think that the 4800's are 2S 2400's bytheway (they do the same with the peak performance cells, those are 2S2P too)
coolhandcountry 03.15.2006 06:20 PM
That is a bigger jump than expected. I would go 3700 at that price.
Gustav 03.15.2006 06:59 PM
I think you'd be hard pressed to notice any performance benefit apart from runtime considering how much power we're talking about already.The extra 200 grams (ish) may settle the truck down a little,help control perhaps.At this level of power,the limiting factor to acceleration is largely traction.It's like trying to notice the difference between crazy uncontrollable power and slightly more crazy uncontrollable power,lol.Should be fun!
I'd just go with what size/weight and how much runtime you want,it'll be mad fast with either.
MetalMan 03.15.2006 08:37 PM
I'd go with the 4800s. They would provide better punch, since they can handle higher amp spikes. Also, since they wouldn't be stressed as much as the 3700s, they should provide more cycles.
nl12 03.16.2006 06:49 AM
4800
http://static.rcgroups.com/forums/at...742324.attach?
info on the 3700, cant find a graph anywhere:032:
http://aircraft-world.com/prod_datas...vx-lithium.htm
