-   -   dumb question (https://www.rc-monster.com/forum/showthread.php?t=25558)
e-rev project 01.28.2010 12:15 AM
dumb question
so i lost my camera charger its li-ion so i wire it to my hyperion
3.4 watt hour is 340mw correct?
thanks
BrianG 01.28.2010 12:22 AM
3.4 watt-hour, or 3.4 amp-hour? If it's amp-hour, then 1C would be 3.4A. However, camera batteries are not usually capable of 1C charge rates usually. I would start at 0.5A for ~8 hours.
_paralyzed_ 01.28.2010 12:25 AM
can you take a pic of the battery and send it to us to help?:rofl::na:
e-rev project 01.28.2010 12:27 AM
i thought watt hour and milliwatt were metric just move decimal, im looking for capacity.....i thought.
it says 3.4 watt hour
lol thanks
BrianG 01.28.2010 01:12 AM
Sounds like you are confusing things a little. Yes, to convert milli to a whole number, you move the decimal left 3 places. So, if a battery is rated 3300mAh, it's the same as saying 3.3Ah.
Watt-hours is different than the normal way most batteries are rated, which is in amp-hours. Power (watts) is volts X amps. Watt-hours=volts*amp-hours. So, if that battery is 3.7v, 3.4Wh means the capacity is 0.92Ah (920mAh); 3.4Wh/3.7v=0.92Ah. Charging that over 8 hours would require a current setting of ~120mA (0.12A).
