-   -   brushless problems (https://www.rc-monster.com/forum/showthread.php?t=25599)
rcsammy 01.30.2010 09:49 PM
brushless problems
Hi everyone, ive been having some problems with my brushless setup in my rustler and i dont know where else to ask as i cant figure it out
after rebuilding it the other day the power seems to pulse, it effects the motor, the cooling fan and the steering
i have changed the motor, battery and receiver to try and work out whats causing it which narrows it down to the ESC or the BEC
im running a Mamba Max with an external BEC(dont know the make) i dont have another ESC or BEC to test it
i have tried plugging the MM in without the BEC but it just does nothing, i have no idea why
heres a video(apoligies for rubbish quality) hopefully it shows the problem a bit more
http://www.youtube.com/watch?v=kOBhbBriwqU
sikeston34m 01.30.2010 10:00 PM
If I were you, I would go make sure I had the latest firmware update for the ESC.
Can you tell more about your setup? What voltage do you have this on?
rcsammy 01.30.2010 10:13 PM
i have reset the MM to default and re installed the latest firmware
im running 11.1v, 3S(turnigy 5000mah 25C) lipo and one of the hobbycity feigao copy motors 2700kv L can
sikeston34m 01.30.2010 10:29 PM
The fan and the steering power is a result of the External BEC. It sounds like it's "dirty" power. The pulsing is probably coming from there.
You said the internal BEC would do nothing when the external BEC was removed. Hmmmmmm...........we need to get to the bottom of what's wrong with the internal BEC.
Had the red wire been removed or cut from the ESC plug that goes to the receiver?
If the internal BEC has not been disabled, then the internal BEC is dead.
This also means your MM Brain Board is running off the external BEC.
When you run an external BEC, you MUST disable the internal BEC by removing the red wire from the Receiver plug.
Otherwise, you have one BEC fighting against the other, especially when one's output voltage is different than the other.
Check the status of the red receiver wire for the internal BEC.
Let me know.
rcsammy 01.31.2010 07:06 AM
yeah the red wire was removed when running the BEC
i put it back in when i tried the ESC without the BEC
sikeston34m 01.31.2010 07:57 AM
You need a new ESC.
If the receiver and servos won't run off the ESC's internal BEC. This means it's VERY weak and can't carry the brain board inside the ESC very well.
Sounds like it's almost cogging.
rcsammy 01.31.2010 03:22 PM
well when i plug the ESC in without the BEC it just does nothing at all, no start up tone,
no lights, no receiver power
well thanks for the help :)
im going to give it one last check over for loose connections or any signs of a fault... then i will have to send it back to castle
