-   -   HB lighting PRO brushless makeover; (https://www.rc-monster.com/forum/showthread.php?t=256)
Serum 03.06.2005 04:15 PM
On this picture you can see the problem of the lighting; The centerdiff is off center. To hold the batteriepacks in balance i decided to reposition the diff to the center of the frame
<img border="5" src="http://rc.stuurmijmail.nl/lightning/1.jpg" width="640" height="480">
PURPLE?!?!?!? Used caustic soda to get rid of it..
<img border="5" src="http://rc.stuurmijmail.nl/lightning/2.jpg" width="640" height="480">
Little bit of elbowgrease and some polish later.
<img border="5" src="http://rc.stuurmijmail.nl/lightning/3.jpg" width="640" height="480">
Motorplate, from 4 mm thick aluminum
<img border="5" src="http://rc.stuurmijmail.nl/lightning/4.jpg" width="640" height="480">
In the middle.. where it belongs... ;)
<img border="5" src="http://rc.stuurmijmail.nl/lightning/5.jpg" width="640" height="480">
<img border="5" src="http://rc.stuurmijmail.nl/lightning/6.jpg" width="640" height="480">
Here is the center repositioning device (CRD ©®)
<img border="5" src="http://rc.stuurmijmail.nl/lightning/7.jpg" width="640" height="480">
And a nice support for the motor, to keep the motorplate from bending.
supermaxx 03.06.2005 04:16 PM
GREAT SERUM!
I can't wait to drive it!
RC-Monster Mike 03.06.2005 04:22 PM
looking good! I was thinking of a similar solution to the off center center diff.
Serum 03.06.2005 04:26 PM
Works like a charm..
I am going to make a fourth mounting hole in it.
If you don't reposition that thing, you aren't able to position the batteries perfect.
RC-Monster Mike 03.06.2005 04:30 PM
Yes, I know this! I had the same problem with mine. I haven't had the time to work on it in a couple weeks, but I was considereing the smae template to move the diff towards the center.
rc4x4nut 03.06.2005 06:43 PM
That is beautiful. If only I didnt my my tickets to hawaii.
Mike, ygm.
Megazone23 03.06.2005 11:33 PM
Boy, it must be convenient to be able to fab your own parts when you need to! That's a nice conversion job.
One question, though -- what is that silver tape for?
Serum 03.07.2005 02:57 AM
I used the tape to align the centerdiff.
RCcarnut 03.07.2005 08:13 AM
Nice work. The CDR looks like a happy face :L:
patch 03.07.2005 10:51 AM
What chassis and center diff is that? I've heard of people using a ofna center also but don't know what model they are from..
patch
Serum 03.07.2005 11:13 AM
It is from the HB lighting pro.
And true, i am also going to build an emaxx centerdiff with an Ofna diff.
Read the 2240 thread by Promod in the brushless section.
patch 03.07.2005 01:25 PM
Found it, Thanks!
1 more question....it doens't say how you would make the brakes work. What channel would you use on the receiver.
patch
Serum 03.07.2005 03:26 PM
I am going to use a Y cable on the gas/brake channel. As simple as that.. ;)
Serum 03.07.2005 05:08 PM
Update;
Well.... I haven’t figured out if i am going to use this things... Took me a lot of time making them, but they don't convince me... I got the material from a person I know. I didn't understand why it was so freaking hard to work on.. Appeared that it was used to make a Audi A8 bulletproof.......... Wish he told me before.. :D
<img border="5" src="http://rc.stuurmijmail.nl/lightning/8.jpg" width="640" height="480">
The subtle motorbrace to be..
<img border="5" src="http://rc.stuurmijmail.nl/lightning/9.jpg" width="640" height="480">
This took some work, it's the servo-holder, i needed to cut some of the nylon to make the driveshaft fit nicely.
<img border="5" src="http://rc.stuurmijmail.nl/lightning/10.jpg" width="640" height="480">
And here is the new Battery Carrying Device (BCD ©) the battery is held on the aluminum plate with Velcro and a few tie-wraps The black things on the front are bumpers, that keep the batteries in place with frontal crashes.
In front of the long aluminum bars, you can seen the black parts i was mentioning. Those where a PITA to work on..
Megazone23 03.07.2005 05:23 PM
Careful using those Audi parts, you don't want your car to suddenly move forwards or backwards without any warning! ;)
