Pack with a cell voltage difference
Hi,
Any ideas if the cell is gone? after hours of balancing still no major change... http://i298.photobucket.com/albums/m...ler/Zippy1.jpg http://i298.photobucket.com/albums/m...ler/Zippy2.jpg |
Maybe discharge the pack some either running it or with charger and reset to charge at 0.5 amps. It will take a long time and probably have to reset charger since it shuts off after 2 hrs but this should bring it around.
IF not, then you might have other problems such as a bad balance tab possibley ? Hope this helps ? |
I had a Turnigy 4s 5000mAh pack do even worse. But after charging and discharging several times (balance) it came back around pretty close. The one weak sell now charges up to 4.19. Close enough for me. But I would still keep an eye on it while your charging it. Don't want no lipo fires :diablo:
| All times are GMT -4. The time now is 12:53 PM. |
