-   -   Mechanical Brakes on Hyper ST? (https://www.rc-monster.com/forum/showthread.php?t=25622)
fastbaja5b 02.01.2010 08:49 PM
Hey, looking at a Hyper ST I am trying to convert (well I have been trying to sell it but getting no bites)
Are mechanical brakes essential? My radio (KO - EX5UR) doesn't have servo mixing so I'd need to use mechanical brakes using a Y lead, would I need to set the ESC brakes to zero so I don't have the motor and mechanical brakes doing the same job? (obviously disable reverse as well)
Does it make that much a difference on these things? Are the gains worth the effort?
Arct1k 02.01.2010 09:15 PM
Not really - electric brakes work just fine unless you are a tuned racer
fastbaja5b 02.01.2010 09:43 PM
Ok thanks, I am looking at using my Hobbywing 80A and 9XL motor geared 17/52 on 4s A123 in this, the calculator estimates a top speed of 33.53mph it's only a temporary set up while I save for a Tekin combo, would this set up be reliable or am I trying to push too much truck with too little motor?
Arct1k 02.01.2010 10:22 PM
I started out running 9XLs for about a year with a MM on 4S lipo - They used to work fine...
We are all spoilt now - Just keep an eye on temps
magman 02.01.2010 10:40 PM
I also ran the same set up in my mbx5 for quite awhile and as Chris said, what temps closely as the 9xl will heat up fast if gearing is not right
fastbaja5b 02.02.2010 12:05 AM
Yeah I appreciate that, I figure geared to 30-35kph as ppl recommend, and with a heatsink fan on the motor I may get it to last, only concern is the relatively low voltage of 4s A123.
