Interesting HV 10S car speed controller??
Buggy of mine sent me this link....are the MGM's any good???
http://mgm-compro.com/index.php?tid=...-boat-z-series http://mgm-compro.com/pics/s-z-series-fan-types.png Controller for motors brushless Reversible controller yes Number of Li-Ion, Li-Pol feeding cells 3 - 10 Number of NiCd, NiMh feeding cells 9 - 32 Number of A123 feeding cells 4 -12 Compatible with any feeding cells yes Operating voltage 9 - 45.0 V Max. continuous current (for full throttle) 125 A Max. peak current (peak 5 sec.) 155 A Version BEC / Switching BEC / OPTO OPTO BEC voltage - V Max. BEC current at 25 °C - A BEC short circuit protection no Number of regulation steps 1024 PWM frequency 8/16/32 kHz On-state switch (FETs) resistance at 25 °C 2 × 0.50 mohm Dimensions 50×31×22 mm 1.97×1.22×0.87 in Dimensions with external capacitor 80×31×22 mm 3.15×1.22×0.87 in Weight without power conductors 81 g 2.604 oz Weight incl. all conductors 119 g 3.826 oz Power conductors cross-section to batt. / to mot. 4/4 mm2 0.0062 in2 Length of the power conductors 110 mm 4.331 in Servocable cross-section 0.25 mm2 0.0004 in2 Length of the servocable 190 mm 7.480 in |
i know a few people who have MGM's. most of them say they are the most reliable of the very high HV controllers for cars although they can be somewhat difficult to program and customer service from what i understand in not in the US.
If you plan on using the full 10s capability, I would use mechanical brakes to eliminate the braking spikes associated with electric brakes. Or use a bunch of caps and TVS devices.
I had only planned on running 8S. I only run 50% brake on my MMM now plus my EPA is turned down on my transmitter as well. I don't use brakes very much and usually not enough to lock the tires up. Kills my lap times.
Difficult programmimng, over seas cutomer service and a 375.00 price tag ?
If MGM has all the issues fixed, then the controller is good. I sold all but one due to a strange situation with a 2.4G radio. You could try a Kontronik Jive 80HV or 120 HV. Get both program cards for full features and the 120 HV's price is up there. It only has one car mode I believe, so it'll be good for racing.
I have a couple MGM's, with the latest firmware they work great.
I have the 90A version of that in my savage on 8S on e-brakes. Not a bad controller at all, but not as refined as castle's. PC programming is easy, tx prog. is ok once you learn their logic (they make it too complicated.) Fairly smooth, but startups not as good as castle's.
Overall a solid controller tho. They had the best HV controllers at one point, but have not progressed much tho. |
| All times are GMT -4. The time now is 02:22 AM. |
